87 NA Differential
  • pokeyquick
    pokeyquick
    Member
    • 44
    87 NA Differential
    Who rebuilds NA diff. in the NC area? Mine is very noisy and I believe that the rear clunk that I'm hearing is coming from it. I have replaced all of the bushing, rear diff mount, and drive shaft u joints. I can hear the clunk when I put it in gear and when I give it gas at low speed or when I pat the gas at low speed but in a higher gear. It sounds like a clanking noise or a metal to metal clunk!!!
  • DMANN
    DMANN
    • 544
    If you replaced the u- joints in the driveshaft you can rebuild the diff yourself.
    If not get another one it will be cheaper.
    88na2T-s13,q45 swap 12.6@110mph
    87T 2+2 auto,stock
