Trans Rebuild Kits
easarcherMember- 96
Trans Rebuild Kits
I have the 71C trans, and it is starting to grind some gears. The tranny is out of the car at the moment, so I wanted to rebuild it. Does anyone have any experience with rebuild kits? If so, what is a good brand? I work at Advance Auto Parts, and I currently have my hands on a Pro-King brand kit.09 Lancer ES 5 speed
86 Z31 VG33E(NA2)T.
"I want it to sound like the pits of hell are going to engulf your face!" -
It might be cheaper to source another 71c in good shape, people with big turbos toss those away regularly… -
jamesSenior Member- 978
How much do you get the kit for ?
I have never done a gearbox myself but a few diff rebuilds, if you have the correct parts and tools and can follow the FSM then i say do it.85 Turbo Slick Top
easarcherMember- 96
I can pick the kit up for for5 bucks, that includes all bearings, seals, and rings.09 Lancer ES 5 speed
86 Z31 VG33E(NA2)T.
that sounds like a soft rebuild kit.
which is just bearings and seals.
no synchros or anything actually worth opening a trans for. -
easarcherMember- 96
It has the brass rings too, but not the synchro sleeves09 Lancer ES 5 speed
86 Z31 VG33E(NA2)T.
easarcherMember- 96
I just noticed my phone didn't catch some numbers. The kit is 105.09 Lancer ES 5 speed
86 Z31 VG33E(NA2)T.
Mitchd03Senior Member- 891
I need one for my POS T-5. Noisiest, notchiest, nastiest gearbox I've ever had in a car with the worlds slowest 2nd gear synchro. The bellhousing doesn't come off the T5 does it? I can't build one on the side then swap them over one day.
GregmaticSenior Member- 2193
It must be a Z31 T5. Mustang, Camaro, 280zx, etc all are not fully compatible, input shaft/bellhousing differences.
GuardianSenior Member- 225
I'm in the process of rebuilding my 71c. Ordered a ebay kit a year ago and now regret. Some of the synchros don't match and also didn't give me all the synchros needed for a proper rebuild. Everything else seems to work. Just ordered a synchro kit from Drivetrain.com. I'll get back to you if I would recommend. So far 300 bucks worth in kit cost. Plus having a friend of mine doing the rebuild for 2-300. But, Even with all that, I would still rather have my own rebuilt tranny then something I'd pick up from a salvage yard. Fresh and clean any day. I'll have no worries about popping a tranny because of the previous owner's failure to properly maintain his car.
Also one very important thing that I found out about the 71c: Nissan loves to change their stuff half way through a year. Their are 83-87 and 87-89 rebuild kits. Very slight differences but it was enough to make me buy another kit.Originally posted by michaelpI tell them that everyday, "thats a good lifter…good lifter. You want a treat? Oil change next week." But on the other hand, the headgasket is a bad headgasket. Hes always leaking out in my cylinders, making a mess on the cars behind me with all that coolant. So I discipline it with 6,600rpm burnouts.
