Z32na trans vs TT vs pathfinder?
G-EJunior Member
- 6320
I know the general answer is they are pretty much the same… what I want to know is are they equally strong, are there any advantages to the TT trans or difference in linkages/shifters etc?
I need this for my rb25 and I have an opportunity to get just the bellhousing I need, so for the back half I want to know if I'd be better off getting a vg30e pathfinder r30a or z32na r30a to mate with it?
In either case I still need a custom driveshaft so that's not a deciding factor
Opinions? Experience? -
NissanEggSenior Member
- 5220
2WD Pathy is your best bet if fitting into a Z31. The Z32 versions are shorter and will require fab work for the shifter and brackets.
RXGhostSenior Member
- 510
But if you are moving the engine back and lowering it like Sham then Z32 is better1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
gardner86zxSenior Member
- 381
NissanEgg wrote: 2WD Pathy is your best bet if fitting into a Z31. The Z32 versions are shorter and will require fab work for the shifter and brackets.86na2t + holset
feedback
CarelessSenior Member
- 13279
G-E, I'd go with the Z32 NA boxes. you can get them for under 200 bucks from importers.
That's why I sold my spare bell housing to RedDemon.
They're cheap and easy to find. He had to make his driveshaft- so that's the unit he settled on.
gardner, by same length do you mean the output shaft seal arrives at the same position as the Z32 box, or they're "roughly" the same size?
i'm axxin' because that's what you're supposed to measure driveshaft length from. Shaft seal/housing to diff pinion flange.
If it's the exact same then I guess the driveshaft length will be the same and you have more transmission to grab from the JY if one takes a shit.
win win? -
- 5220
What about the 5-speed behind the VG33 in the later Xterra and Frontiers? Are they not 30A?
G-EJunior Member
- 6320
NissanEgg wrote: What about the 5-speed behind the VG33 in the later Xterra and Frontiers? Are they not 30A?
Looks like I'll be able to get a z32na (missing shifter/bracket) + rb bellhousing for $400 shipped… still leaves me open to selling the z32 and getting a pathy/frontier back half if it proves problematic
