Tranny Mount Damper Bushing
What options are there beside poly filling.Cha iro
NissanEggSenior Member- 5220
Removing or cutting off or welding solid.
DeleriousZSenior Member- 6874
If you mean 'poly fitting' as in filling it with window weld or whatever; there's a completely separate replacement tranny mount that's made of polyurethane.
1990 jetta vr6'd -
The bushing in the dumbell part. I think there used to be a poly replacement back in the day?DeleriousZ wrote: If you mean 'poly fitting' as in filling it with window weld or whatever; there's a completely separate replacement tranny mount that's made of polyurethane.Cha iro
Window weld it if you can't find something. I've used it for more important things with no issues.5.3 LSx Z31 -
MADMIKESenior Member- 1533
Get the poly bushing, they are still out there. I scored mine last week, Finally.....DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
im thinking of cutting the dumbbells off a spare mount I have and welding a pair of large washers onto the holes for the bushings to act as solid bushings. i like the way the solid engine mounts feel so it's the next step i guess. lol -
yeah I am going full poly, but it turns out a buddy of mine has a CNC in his garage, I may start banging out some solid bushings if I choose to go that direction.DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
Make me a set.MADMIKE wrote: yeah I am going full poly, but it turns out a buddy of mine has a CNC in his garage, I may start banging out some solid bushings if I choose to go that direction.Cha iro
andyray187Senior Member- 204
used poly urethane window sealant on mine seems to work just fine. i cant wiggle my trans side to side with my sifter any more. -
That's how we did Altima Motor mounts back in the day. Holds up pretty decent. I just feel it is a bit of a bandaidDD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
after working in a body shop and watching the glass guy battle that window sealant every day i trust it as more than a band aid. that stuff is solid and stuck when it dries it has to be cut out and ground off. ill use it when its minor i wouldnt poly fill a controll arm bushing or anything like that. -
Having used it in a lot of different rubber bushings I'll admit that it will hold up very well if it's installed anywhere where it can be kept in compression all the time. I've done dozens of Toyota engine and diff mounts. The 'windo-welded' isolator bushings on my 87 are only slightly less stiff than the poly bushings that used to be available.MADMIKE wrote: That's how we did Altima Motor mounts back in the day. Holds up pretty decent. I just feel it is a bit of a bandaid
