Which friction modifier do you prefer?
SKOLJACKSenior Member- 305
I have been unable to find the Pennzoil #4096 LSD Oil (PPC # 020796), but did have some Shell 80W-90 that meets the GL-5 rating. My question is, which friction modifer do you guys use or prefer to use when changing your CLSD fluid?
I have used the Ford product at work in all of our Crown Vics and it seems to work well with them.
But I also use the Redline products in my T-5 trans without any problems.
Or if there are any others, let me know (these two are in stock at Summit Racing).
Az4u2cSenior Member- 793
Crown Vics with LSDs? whoa. News to me.
Sorry I can't offer any insight to your question.My beloved Z:1987 2+2 NA2T w/30a swap.
207k miles and counting. Turbo'd since 155k. -
bemisSenior Member- 696
I thought the oils and additives had to meet GL-4 standards, not GL-5.1984 300ZXT
1986 300ZX 2x2 NA2T
2000 Porsche Boxster
2007 Toyota Yaris -
Neil86tSenior Member- 1904
I used the Redline stuff…seems to be working.Elitist Prick Black Z owner.
1986 300zx Turbo
I use the additive I get at a driveline shop. I believe it is the same product made for Ford LSD's but in a generic version so it's cheaper.
GL-5 is fine for your diff, but just to warn people DO NOT USE GL-5 in your nissan manual transmission. -
SATANSenior Member- 6782
So what does the GL-5 do to the tranny? Are the redline fluids GL-5? cause I have been running that for a while now :shock:Jason84NA2T wrote: I use the additive I get at a driveline shop. I believe it is the same product made for Ford LSD's but in a generic version so it's cheaper.
GL-5 is fine for your diff, but just to warn people DO NOT USE GL-5 in your nissan manual transmission.85 Z31 6.0 LSX turbo 766whp/792wtq
[quote]SATAN wrote:Originally posted by Jason84NA2TI use the additive I get at a driveline shop. I believe it is the same product made for Ford LSD's but in a generic version so it's cheaper.
GL-5 is fine for your diff, but just to warn people DO NOT USE GL-5 in your nissan manual transmission.It reportedly has additives that erode some of the elements used in older nissan transmission blocker rings, eventually causing synchronizer failure. I've heard this from numerous sources so far, and combined with the number of Nissan manual transmissions that have gear grinds with very few miles on them I figure it might be good to get the word out. I don't know if it's applicable to the T5 or not, but I would assume not.Originally posted by Jason84NA2TSo what does the GL-5 do to the tranny? Are the redline fluids GL-5? cause I have been running that for a while now :shock:
I've been told that Redline and all other synthetic oils are GL-5 certified without the purposed harmful shock additives, meaning they are safe for transmissions you should otherwise not use GL-5 in. -
OR-ZmanSenior Member- 811
Redline in the trans and diff here.
I like the results. I noticed a bit nicer shift when I started using it. Not much of a way to qualify the diff oil other than longevity.Just stand back and throw money.
Performance costs money.
Reliable performance costs more. -
ButterSenior Member- 1519
Everyone here needs to go for a trip around the block in my car so I can expose you to the diff oil additives test bed. :lol:
Jason knows.
I've tried all of them. The winner is…
with conventional 80w-90.
The Kaaz and cusco, etc oils are even better, but nobody here would buy them.sigpic -
KennedySenior Member- 1158
Signal 12Senior Member- 553
those using redline in the diff…are you using MT90 or something different?2008 BMW E92 335i 6MT -
Taris BlueSenior Member- 537
Wow dude…simply brilliant, I just put some of this Kedall additive in with some new 80w-90 and my chatter is gone…then went and beat the shit out of it…amazingly smooth. Thanks so much for the tip, it gets a thumbs up from me.Butter wrote: Everyone here needs to go for a trip around the block in my car so I can expose you to the diff oil additives test bed. :lol:
Jason knows.
2006 Scion tC (Wife Whip)
In an ideal world I would have all ten fingers on my left hand, so my right hand could just be a fist for punching. -
I know, every body here uses it now. Like $7 per diff fluid change vs $35 with the aftermarket LSD oils. Stuff smells like shit though.sigpic
