Transmission Tools
DaftZXMember- 61
Transmission Tools
Taking apart my N/A trans … FSM says to use kv32101330 but I cant find it anywhere… anyone know where I can buy one?? -
Look at some generic bearing puller kits. I doubt you'll find that tool anywhere.
Nevermind, I found it under the alternate part number. Not cheap.
http://tools.nissantechmate.com/Detail. … =J-26349-A5.3 LSx Z31 -
u can make it yourself. go to a fastener store and get some all thread that fits the same thread as the steering wheel puller tool which those attachments are made for:
http://tools.nissantechmate.com/Detail. … =J-25726-B
then just cut some steel plate to fit behind the gear cluster that you want to remove, and thread it or weld a nut on it. weld a coupling nut onto the end of the all-thread to be able to turn it with a ratchet/wrench.
Boozt3d on hybridz did something similar after ordering a 2500 dollar snap-op jaw puller that wasn't working as planned.
