Q45 diff to driveshaft flange
cesarSenior Member- 136
Hey guys I have been calling driveshaft shops to get the flange for my driveshaft since I went with a Q45 diff on my s13 subframe swap and none have the specs for them :-? . Just wanted to know if anyone knows the specs or where I can buy one?
Thanks,
Cesar -
Yeah thats what I will end up doing the thing is it's a 2 hour drive plus everything is all bolted up but I might have to just take it down and take the diff. -
Found this while searching http://www.drive-lines.com/catalogs/mas … nge%20yoke seems like the part number is 3102-69 but will verify tomorrow -
RedDemonSenior Member- 362
This is what I sent Shaftmasters when I ordered my driveshaft. Ignore the length if you're using a stock tranny, 1010mm is if you have a z32 transmission/s14 sub-frame combo.
1988 SS #71
Better to remain silent and be thought a fool, than to speak and remove all doubt. -
I'm not really sure if I have the 90-96 or the 97-01 diff. The guy I bought if from told me but I forgot.1988 SS #71
They are 6 bolt axles1988 SS #71
Nice! So that means you have a 90-96 q45 diff, you have a q45 axle and one twin turbo axle correct? Later ones are 5 bolt axles
