2005-2007 Pathy final drive
  • stufferton
    stufferton
    • 467
    Found this last night in my attempt to locate a different tidbit of info about the lowest final drive available for the r200 diff. I was hoping to find the one that was in, IIRC, a 1978(or maybe 79) 280zx 2+2 turdblo. Available only in…Canada? I read it ONCE and cannot remember where for the life of me…but stumbled across this instead. Figured it would be a good thing to start a bit of a chat about.
    http://www.nicoclub.com/Greg/ratios.html#Pathfinder
    This WOULD still be in production and available from Nissan directly I assume, and would offer great benefit for either people wanting super gas savings @ 70-80mph, or a top speed high HP beast.
    /discuss?
    Build thread http://z31performance.com/showthread…-Paint-done-eh
  • Guest's Avatar
    Guest
    Ok, this confuses me and I've heard it a lot of different ways.
    Is 3.54 low or high? I would assume 3.54 would be low and 3.9 would be high.
  • stufferton
    stufferton
    • 467
    I've heard it a couple of ways, low/high (which yes is confusing because the number is low, yet maximum speed attained is higher), and short/tall.
    I prefer the short/tall expression because it is alot more straight forward and makes sense to (I assume) more people. These would be VERY tall gears, probably push a 6500 redline close to 180mph (ROUGH guestimate, no calculations made what-so-ever)
  • Guest's Avatar
    Guest
    I call 3.54 low because it's a lower number and your engine turns a lower number of turns to reach a speed. Just makes sense.
  • Kingman
    Kingman
    • 1294
    #5
    "Lower" has a higher numerical number. "Higher" has a lower numerical number.
    Low gearing would be for example 4.88s and higher would be 3.54s.
  • stufferton
    stufferton
    • 467
    #6
    Hence why I still prefer short/tall, lol. I guess I have a question in here as well. Since this is the final gear for an r200, all that would be required to acheive this ratio would be the…big ring around the outside of the spider gears…DAFUQ is that one called again, drawing a blank at he moment…
    EDIT: I got it, Google saved me. The ring gear DERP.
  • Guest's Avatar
    Guest
    #7
    That's what I hated about my pathfinder. Had it had a better rear gear I wouldn't have sold it.
  • stufferton
    stufferton
    • 467
    #8
    So correct me if I'm wrong, but if I wanted the taller ratio I would just need to either pilfer the ring gear from the correct pathy in a JY, or order JUST the ring gear from Nissan? I know the final ratio has something to do with the number of teeth on the ring gear, combined with…the number of teeth on the spider gears??? (I think) Do all r200's have the same number of spider gear teeth?
  • Guest's Avatar
    Guest
    #9
    the ratio is the number of turns the pinion has to make to turn the ring gear once. For example, 3.54:1 means the pinion has to turn 3.54 times to net 1 revolution of the ring gear.
  • 85NA2T
    85NA2T
    • 1111
    #10
    you shouldnt mix and match ring and pinions.They should be used in sets.
    "If your car cant do a burnout from a 60mph rolling start, then your engine needs more work."
    Shooting for 500whp
  • stufferton
    stufferton
    • 467
    #11
    http://www.ka24development.com/vlsd.html
    About 1/4 of the way down the page its explained that you can calculate the final drive ratio based off the number of teeth on each gear, so depending on how many teeth are on our output gear vs that nice tall pathy output gear, one would assume that the same number of teeth would net us the same ratio without buying both gears.
    As to not mix and matching, is this generally a bad idea due to potential gear angle and height of the teeth and other minute details that could cause a binding issue? Is there a way to find out exactly what the profile of the output gear is to judge whether buying both is necessary?
  • G-E
    G-E
    Junior Member
    • 6320
    #12
    Each diff will have a number stamped on the ring gear, it will tell you how many teeth on the ring and pinion, then you do maths to find out the ratio
    Like 37/9 or 39/11 etc
  • MADMIKE
    MADMIKE
    • 1533
    #13
    Either or I think the 3.133 will not work. Most nissan's are shortnosed R200s
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • NissanEgg
    NissanEgg
    • 5220
    #14
    The Pathy R200's are short nose. You can use them in the Z31 rear crossmember, but will need to get creative on attaching it properly and lengthening the driveshaft.
    If you had a S-chassis swap, it might be easier to swap into one of those rear setups.
  • Careless
    Careless
    • 13279
    #15
    you're asking about the 3.36 R200 in the 280zx turbo+auto. there was also an R180 version in the 260z.
    http://www.geocities.com/inlinestroker/ratio.html
