88n/a stage 2 clutch specifications
legenddd22Member- 69
Hi im new to this....can anyone help me with finding the rite clucth for my z31 N/A?
Also can a 240 sx clutch fit my z? -
Dave@SBCSenior Member- 494
easy! If you're basically a stock car looking for a heavy duty version of a stock clutch, the stage 1 HD would work very well. Holds 300tq and runs $225. If you're interested in something a little stronger, that can hold a little more power or abuse, the stage 2 Daily is not much more at $265 and holds 315tq. The difference is the friction material. The stage 1 is a stock pressure plate with upgraded friction material, the stage 2 daily is a modified pressure plate with the same upgraded friction material. The modified pressure plate is generally around 100-150lbs of extra clamping force over stock. Of course, more clamping on the disc results in more torque holding.Dave
Z31P sponsor
800-988-4345 ext: 114
http://www.DXDRacingclutches.com
90 Z32 Base 5spd, 05 Z33 Touring 6spd.
SOLD- 84 Z31 NA2T GLL 5spd
Thnx,i appreciate it…being the same tranny as the 240sx,will i have to do any mods so the aftermarket clutch cud fit my z.? -
zachary.ardBenevolent Dictator- 1629
Just to reiterate what Dave said - I tried to make the information easy to understand across all of the clutch options here:
http://store.acadianasportscars.com/cat … -non-turboChicks dig me, rust fears me. -
Thanks guys,the prices they list is wat i expected to spend,.
As for the brand DXD, ive never heard of it,you guys have one on your z,how does it feel?
