Z32tt bellhousing and Z31 30A bellhosing
THEBEASTSenior Member- 567
i know the tt bellhonsing is thicker where the started bolts up, but what else is different between a z31 and a z31 bellhousing? i searched, but i could find any info on what im asking -
nismopuAdministrator- 2221
Starter location is the only difference on all z32 bellhousings."Its the s12's sexy over weight step daughter, the z31" -
nismopu wrote: Starter location is the only difference on all z32 bellhousings.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
I dont have bellhousings here to compare the starter locations. would a Z31 bh bolt up to a vg30de block? If so, could a z31 bh and starter bolt up and operate proper? -
They will bolt up just fine. You need to use a z32 starter and a maxima flywheel when using a z32 bell."Its the s12's sexy over weight step daughter, the z31" -
Holy crap I did not know this. Very interesting.....
soooo the starter location, is it way off from where the z31 starter would be? how is it different? could i use a z31 bell on a DE? the tt fly is 250mm, and so is the 88t, so i SHOULD be able to use a tt fly and a z31 starter. -
NissanEggSenior Member- 5220
TT flywheel is 8-bolt.
Z31 flywheel is 6-bolt.
Huge difference.
The starter on a Z31 sits next to oil pan and has bolts that go thru the bellhousing and the plate to the starter
The starter on a Z32 bolts onto the side of the bellhousing and the bolts are perpindicular from the bellhousing surface.
Google the images. To make a Z32 bell housing and starter work you would have to cut a hole in the floor to make clearance.
exactly what i was looking for. there is no way around it, to swap a vh and keep it manual, you have to use z32 fly, bellhousing, and starter. thanks egg.NissanEgg wrote:
Google the images. To make a Z32 bell housing and starter work you would have to cut a hole in the floor to make clearance. -
Wtf? No. 250mm has nothing to do with diameter of the total fly. It only has to do with the surface area of the clutch. Not too mention the often overlooked Nissan pathfinder used a 250mm fly."Its the s12's sexy over weight step daughter, the z31" -
i have a 88t fly on my car, when i swap the vh in, im going to use a 250mm tt fly because ill be able to use the dxd i have. i have seen 2 Z31s with the vh swap, but both used a different adapter plate. since im goin a differnt route, i need different answers and info. thank you for the help. i dont have all the parts yet, so im doin what i can to learn it all. -
ooooooooooooooh You are doing a VH swap. lol! I totally missed that part and makes more sense now.THEBEAST wrote: i have a 88t fly on my car, when i swap the vh in, im going to use a 250mm tt fly because ill be able to use the dxd i have. i have seen 2 Z31s with the vh swap, but both used a different adapter plate. since im goin a differnt route, i need different answers and info. thank you for the help. i dont have all the parts yet, so im doin what i can to learn it all."Its the s12's sexy over weight step daughter, the z31" -
I find this very hard to believe.NissanEgg wrote: To make a Z32 bell housing and starter work you would have to cut a hole in the floor to make clearance.Cha iro
[quote]Augustus Maximus wrote:I do too.... :lol:Originally posted by NissanEggTo make a Z32 bell housing and starter work you would have to cut a hole in the floor to make clearance.
I find this very hard to believe.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Did he cut a hole?NissanEgg wrote: To make a Z32 bell housing and starter work you would have to cut a hole in the floor to make clearance.I find this very hard to believe.
JoCkeWe wrote: All it takes is some love, and a hammer, cause the maxima-starter won't fit without a slight touch of violence to the chassie.
Works perfectly, after some violence.. :-)Cha iro
