Can you use the clutch fork from the t5 in the n/a
 epyonz31Member epyonz31Member- 80
 Can you use the clutch fork from the t5 in the n/aI cant find the clutch fork for my n/a trans… would i be able to swap the parts from my turbo trans?Z-DZ-NUTZ
 Guest Guest
 Re: Can you use the throw out bearing from the t5 in the n/a
 I think the bearing itself is the same but the fork and hub are different.
 would anyone happen to know the part number for the non turbo clutch fork? for some reason i can only find them under turbo charged.Z-DZ-NUTZ
 z-flashSenior Member z-flashSenior Member- 423
 http://www.courtesyparts.com/kb_search_ … ?keywords=[30531]+(z31&cPath=2317_2318_2391_2405
 EDIT: just click on the clutch fork number and it displays the options....
 http://www.courtesyparts.com/300zx-part … _2405.html
 Here is a screen shot:
