Clutch Fork Options
 the difference is dave advertises the clutch as a modified z33 pressure plate.MADMIKE;319643 wrote: Nor has it been a mystery.... That would be like saying OMG the SBC upgraded pressure plate is the same as the Z33 Pressure plate.
 zspeedperformance, to my recollection, never indicated what the fork was from- so many didn't know it was from a z33. myself included.
 MADMIKESenior Member MADMIKESenior Member- 1533
 Cool enough. I bought mine through Zspeed one of the main points of this mod for me was the Cromo Pivot. The Fork is no less important to me, though obviously.DD:
 86 Black Turbo 5spd
 The Fallen:
 Parting Currently:
 Garage Sale
 The cromoly ball wears out regular forks quickly from what I hear, the beefy z33 fork should last a while
 -Strike-Senior Member -Strike-Senior Member- 1968
 I may take the dive and do this upgrade..The time is right to do it, everything is taken apart right now, and the swap would be easy… hrm. Shipping is a bit much, though.
 If you have a heavy loaded pressure plate i would 100 % recommend this upgrade.-Strike-;320870 wrote: I may take the dive and do this upgrade..The time is right to do it, everything is taken apart right now, and the swap would be easy… hrm. Shipping is a bit much, though.Usual Z31 suspect: Garage Queen (aka broken)
 Ordered this morning, they've already shipped. Nice. Shipping is a little spendy for us up here in Canada. But, I am used to paying at least an arm, and most of the time the leg as well.
 Dave@SBClutchJunior Member Dave@SBClutchJunior Member- 4
 That's only for my 350z lower staged stuff.. all the Z31 and Z33 SS (aka stage 3) are a 350z pressure plate that is not available from Nissan. They average around 2700lbs of clamp load with no modification. The 'stock' Exedy 350z pressure plates are 1790lbs, my standard modified Exedy is 1910lbs and a blown out Exedy is around 2300lbs. That being said, I have modified the SS pressure plates up to 3800lbs on a 'blown out' version and have held over 800tq.Careless;319652 wrote: the difference is dave advertises the clutch as a modified z33 pressure plate.
 flatfootSenior Member flatfootSenior Member- 253
 All right I gathered already it doesn't fit the 71C tranny. Does it interchange between the fs5r30a and and the fs5r90a??Life's short
 Go fast
 Have a blast
 Leave a good looking corpse
 shromySenior Member shromySenior Member- 2189
 No. 30a only.flatfoot;327224 wrote: All right I gathered already it doesn't fit the 71C tranny. Does it interchange between the fs5r30a and and the fs5r90a??Hmmm, Whats next?
 84ZXT
 So maybe I'm lost in all this discussion, if a 71c is only really good at taking say 300tq, you don't exactly need a heavy heavy pressure plate for that, and if you do get a hugely capable clutch in there for a higher power car, aren't you just asking for exploding gears? Shouldn't you be switching to a '30a instead?
 Yes, but 30a can be hard to find and 71c are plentiful enough to blow a few up while looking.G-E;328370 wrote: So maybe I'm lost in all this discussion, if a 71c is only really good at taking say 300tq, you don't exactly need a heavy heavy pressure plate for that, and if you do get a hugely capable clutch in there for a higher power car, aren't you just asking for exploding gears? Shouldn't you be switching to a '30a instead?Hmmm, Whats next?
 84ZXT
 That's why the Z32 easier to find and stronger 30A.Cha iro
 at least you gave it a whirl.
 Speaking of I need to make the time to go get bell housings! The last month has brought a new job. A long commute, looking for a closer residence and even less time .
Hmmm, Whats next? .
Hmmm, Whats next?
 84ZXT
 I'm testing the Maxima setup in the next two weeks. Prepping for the engine hoist as we speak. Let's say I'm kinda curious.Cha iro
