Issue with turbo axle not staying in the diff?
turblownSenior Member- 400
I'm replacing the passenger side cv axle on my 85 turbo. I picked up a remanned unit and got to installing it today. It bolts up fine but seems short. What I mean by that is, the diff side of the shaft wants to pull out of the diff by 1/2-1". I can pull the shaft over (from tire to diff) and it snugs into the differential just fine, but then wants to pull out. I checked with the parts house and I have the correct side axle.
So, I look at the FSM (page RA-12) and see that there should be a "circular clip A" on the diff side stub. My OEM one did not have a clip on it, neither does this remanned one. I know the axle has play left to right to account for suspension travel, but here's my question: is the axle too short, or it is supposed to snug into the diff and then "circular clip A" holds it in? If it's the latter, does anyone know where I could pick up a clip the right size?Attached Files- sta-cut.jpg (52.1 KB)
1985 300ZX Turbo GLL ^Click for log^
Originally posted by nater86zxNo such thing as hoarding Z parts. When it comes to z parts, its not hoarding its preparedness! -
datsunzcar84Senior Member- 740
did you match it up with the old one? because i know the one side is shorter than the other … Maybe it got boxed wrong?D@MN IT FEELS GOOD TO BE A GANGSTA
Yea, they're the same, I just got a better look at the issue now. There IS a c-clip, but the old one is stuck in the diff and keeping the new shaft from locking in. I'll get that c-clip out of the diff and put it onto the axle and it should work.84z2+2;323635 wrote: did you match it up with the old one? because i know the one side is shorter than the other … Maybe it got boxed wrong?
if you're going to remove the diff carrier itself to get the clip out, be prepared for a fight with the ring gear bolts.
ONLY because the ring gear bolts are tough to remove most of the time (although I'm sure someone is going to say 'never was a problem for me' like it makes a difference), I would say just use a rubber mallet on your axle boot and try and seat it into the diff. with the suspension loaded. I managed to drop the car onto 2 blocks of wood and get under the rear and hammer it in. you can hear it click in.
if that doesn't work, then pull the diff out. -
Yeah the ring gear bolts were a pain for me. A little bit of heat to soften the loctite worked for me.
When I pulled my axles there was also no c-clip on the stubs. I assumed they were supposed to stay inside the diff… -
I'm not sure where the c-clip is supposed to say. some say it comes out with the axle, but then fighting it to go in is a chore. some say that it's supposed to stay in the diff. I think it's supposed to stay in the diff.frostvectron;323657 wrote: Yeah the ring gear bolts were a pain for me. A little bit of heat to soften the loctite worked for me.
That gives me an idea. Maybe I should go pull apart the CLSD in the garage today since I have time. I just hope I can actually take that fucking ring gear open. I kinda don't want to heat it up because gear oil is the smelliest smell that ever smelled in all of smellsville. -
Yeah it is a pretty awful smell. I took mine apart in a laboratory, so I just put an exhaust vent right on top of it. Just 2-5 seconds with a propane torch and they came off like butter though.
Still smelled like I was going to get cancer. -
amrebootBanned- 9875
I have never seen the C clip come out with the axles.
The passenger side axle is longer than the driver side.
Chances are you got the wrong axle.
I would not even think about taken apart the diff to remove the C clip. Leave it in there.
Get the right axle and use a rubber mallet to tap the new axle in place. -
I've had one C-clip come out of the datsun I used to own (R180 diff). to put it back in, I squeezed it into the hole and used the nose of the axle shaft to slowly push it in until I heard it expand/click. then i pulled the axel back and gave it a nice quick jab and it clicked in.amreboot;323664 wrote: I have never seen the C clip come out with the axles.
also, it took multiple tries. not as easy as it sounds. at least not for me. -
I tried today to jab it in and it refused to go in. I tried tapping it in as well without much success. It's so hard to get a good tap on it without messing up the boot, any tips for that? I agree it is harder than it seems. I thought I could just bump it in. I even tried a pry bar on the wheel side to push the shaft into the diff (no success though).amreboot;323664 wrote: I have never seen the C clip come out with the axles.
Get the right axle and use a rubber mallet to tap the new axle in place.I'll take a measurement tomorrow AND talk to the parts house and see if I can identify the axle by a number on it, rather than on the box. It's boxed as a passenger side, though that doesn't mean it is, lol. Thanks dude. See below for my comment tapping it in.
Careless;323666 wrote: I've had one C-clip come out of the datsun I used to own (R180 diff). to put it back in, I squeezed it into the hole and used the nose of the axle shaft to slowly push it in until I heard it expand/click. then i pulled the axel back and gave it a nice quick jab and it clicked in.
Thank you both for the help. Of course with my Z, a simple repair is becoming a mystery multi-day repair…lol.
Try lowering the sub frame with the diff. Have a extra pair of hands keeping axle straight and beat that bitch like you caught your wife cheating.Cha iro
LOL! Seriously though, I wasn't sure if I could put a lot of force on the wheel-end of the shaft. I was afraid I would hurt the joint assembly or something. So, it's OK to beat on it?Augustus Maximus;323696 wrote: Try lowering the sub frame with the diff. Have a extra pair of hands keeping axle straight and beat that bitch like you caught your wife cheating.
it could be that your c-clip is hanging down inside the diff and it's broken.turblown;323684 wrote: I'll take a measurement tomorrow AND talk to the parts house and see if I can identify the axle by a number on it, rather than on the box. It's boxed as a passenger side, though that doesn't mean it is, lol. Thanks dude. See below for my comment tapping it in.
take the axle out completely and look inside.
and no, don't beat the shit out of the axles if you don't know if the c-clip is the problem yet. you might make it a problem if you're not careful, and pulling the differential out when you don't have to isn't my idea of a calm sunday afternoon when it doesn't have to be. -
No, the clip isn't broken. I can see into the diff, and it's just sitting in the recess where it should. From trying to get it out today with a screwdriver, I can affirm it's not broken or bent, looks pretty much normal. I have a clip I found in the broken axle (I think clip "B" from the FSM). The one in the diff looks just the same. So, I don't think it's broken or bent. It's probably more that this Z hates me, lol. Yea, pulling the diff is something I'd rather not do. I already had it down to do bushings, not fun, lol.Careless;323701 wrote: it could be that your c-clip is hanging down inside the diff and it's broken.
