what clutch for 400-450hp?
  • millsaps
    millsaps
    • 133
    i plan to go holset and in the end want 400hp don't want to buy a clutch twice. i have a spec in my truck holds great but thats like 120hp, my s13 had some nice stage 2 and 300ish. what will i need for a z31 at 400?
  • Axel kain
    Axel kain
    Moderator
    • 1221
    sigpic
  • NissanEgg
    NissanEgg
    • 5220
    Clutches are rated in torque capacity, not horsepower.
  • 300zxturboftw
    300zxturboftw
    • 3709
    Go with DXD/South Bend Clutch kevlar kit. Clutch will last you a long time and hold down as much power you will ever throw at it or until you blow up your engine.
  • Careless
    Careless
    • 13279
    #5
    i loved the dxd stage 4 I have in z. its easy to drive and holds anything i put it through. although, i did find downshifting smoothly with a heavy clutch to be a little more finnicky. maybe when it starts to burn in a bit more it would be easier.
  • millsaps
    millsaps
    • 133
    #6
    the stage 3 daily is rated at 530 ft/lbs. i wouldnt be running extremely sticky tires. it would also probably make a few passes on the strip. anyone use the dxd stage 3 daily? it will be through an na trans.
  • NissanEgg
    NissanEgg
    • 5220
    #7
    That's what I run, at least before they changed the lineup of the staging names. I love it. Not to hard on the pedal, smooth engagement. Clutch does make a hissing noise as it is slipping when starting off in 1st or reverse since it has the feramic disc.
  • millsaps
    millsaps
    • 133
    #8
    NissanEgg;329615 wrote: That's what I run, at least before they changed the lineup of the staging names. I love it. Not to hard on the pedal, smooth engagement. Clutch does make a hissing noise as it is slipping when starting off in 1st or reverse since it has the feramic disc.
    better than the throw out bearing whine in my d21, what is done to your motor and about how much power are you making
