Rough Downshifting
TrbulntSenior Member- 347
Maybe you didn't see the "per se" part of my post. You shouldn't need to change/adjust anything if all the parts are in proper functioning order.Careless;340737 wrote: unfair assumption.
you can change the slave rod to a longer piece.
you can adjust the pedal rod with the two jam nuts by removing the snap-pin and adjusting it from inside the car. -
flatfootSenior Member- 253
Usually when my nwc T5 grinds between gears its time for a rebuild and a clutch upgrade.
I've got it down to the point where I can rip the sucker out Friday after work and drive it home on Sunday night.
There isn't a lot to rebuilding a nwc T5.Life's short
Go fast
Have a blast
Leave a good looking corpse -
862sikSenior Member- 2159
IF it was adjusted to the old setup incorrectly and you put the new stuff on, then you still may need to adjust it. Lets say you adjusted the master so that there is no play in the pedal due to possibly a bad master or slave. When you put your new stuff on and its working correctly, the extra adjustment will probably put the new adjustment slightly out of where they should be.Trbulnt;341176 wrote: Maybe you didn't see the "per se" part of my post. You shouldn't need to change/adjust anything if all the parts are in proper functioning order.My Build Thread
