Automatic Bellhousing
 gorekillSenior Member gorekillSenior Member- 228
 Automatic BellhousingHeya all, getting another Z soon that is automatic and I want to know if the bellhousing for the automatic is the same as the 5-speed? Basiclaly I want to know if my auto bellhousing can bolt up to my Z32 transmission like the other 5-speed Z31 transmissions do?Z31 owner as of 27/04/12!!! Sitting in my driveway as of 29/04/12!!!
 Let the madness begin!
 The Z31, Pathy, Nissan, 30A bolts up to your Z32 tranny. Auto bellhousing is not going to work. Here's a question for you. Where would you put the slave cylinder, clutch fork, pivot ball etc. Do tell .
Cha iro .
Cha iro
 at least you gave it a whirl.
 That's why I asked. I know the VG33 and VG30 are the same motors with the same pre-drilled holes, just the accessories are in different places, etc. That's why I was asking. And I also thought that the Z32 wasn't a direct bolt up, due to the starter motor; that you needed to mount the back end of the transmission to a Z31 bellhousing.Z31 owner as of 27/04/12!!! Sitting in my driveway as of 29/04/12!!!
