what size clutch do i need
 steveyJunior Member steveyJunior Member- 13
 what size clutch do i needI've killed the standard clutch while drifting last week , now the problem i have is the car is a mix of parts so i don't know which clutch i have without removing the gearbox. Is there anyway of telling without having to strip it all down ? the engine came from a 88 turbo but has a t3 fitted when I stripped it out and has the 30a gearbox in it , is there any engine number etc ? sorry if this has been asked before but I can't seem to find anything that might help . cheers
 The clutch you need is based on the transmission you have. If you have a 30A you need a clutch for an 88-89 turbo.Prius… because Pretentious wouldn't fit across the back of the car…
 My 1986 Turbo Build
 Well i just checked the gearbox again and its a 30A gearbox , which is a problem … I live in the UK so parts arent easy to get hold off, Only clutch i had found to buy (atermarket) is the 240mm one , Now looks like i need a 250mm one ...... Doh
 You can use the 240mm clutch if you get the matching flywheel… maybe you can find one of those too aftermarket
 I think im using a 240 with the chromoly aftermarket flywheel.Usual Z31 suspect: Garage Queen (aka broken)
