clutch fork seal
xanmanz31Senior Member
- 218
clutch fork seal
im looking for the seal on the housing the the end of the fork goes through to the slave cylinder. can anyone tell me where to find it or what its called? i checked the fsm, haynes, ect -
ZEricMZSenior Member
- 455
Are you talking about the rubber grommet deal that has two lips, one inside transmission and one outside, where the clutch fork comes out of? I ordered one from rockauto or courtesy nissan I believe.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 218
- 455
What transmission do you have? I could search courtesy or rockauto for you quick and give you the linkBuild Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 218
ZEricMZ;n768949 wrote: What transmission do you have? I could search courtesy or rockauto for you quick and give you the link -
- 455
Oh I don't want to speak out of my ass here. I don't know casting numbers on transmissions. If I had to take a guess, I would say that would be the # for a 71c. Better yet, what year/turbo or na? If it is the original transmission, I could just tell you the model from that.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 218
ZEricMZ;n768996 wrote: Oh I don't want to speak out of my ass here. I don't know casting numbers on transmissions. If I had to take a guess, I would say that would be the # for a 71c. Better yet, what year/turbo or na? If it is the original transmission, I could just tell you the model from that.
checked registry and only says man or auto -
- 455
Alright then its a 71c more then likely. Any non turbo 5 speed were 71c's so I would put my money on that. Looking for the link to what I believe you need, one minute.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 455
http://www.courtesyparts.com/30542-c…-p-186756.html
Does this look right? If I understood you correctly, you need this.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 218
ZEricMZ;n769027 wrote: http://www.courtesyparts.com/30542-c…-p-186756.html
Does this look right? If I understood you correctly, you need this. -
- 455
What I did when I filled my trans is I used the side port and ran a hose into the cabin. Let the gear lube sit in hot water for like 10 minutes and then fill it. Makes it a little easier and faster. You could use the top I believe but don't quote me on that.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
- 218
ZEricMZ;n769046 wrote: What I did when I filled my trans is I used the side port and ran a hose into the cabin. Let the gear lube sit in hot water for like 10 minutes and then fill it. Makes it a little easier and faster. You could use the top I believe but don't quote me on that.
