lsd torque limit
cjz31Junior Member- 32
lsd torque limit
So I'm swapping an ls1 into my 87 300zx and the last things need are the drive shaft and a new rear end. I want to know how much torque the z31 vlsd can handle -
turbofedzSenior Member- 289
The problem is not the r200 is the axles.i have seen 240z with big v8ts on them with the r200 not sure what axles they were using but I'm sure not stock. -
1986zxtSenior Member- 482
I've read folks start having issues with the axle stubs around 500 torque1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
If NA, your LS will never break anything in the Z31 drivetrain.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
amrebootBanned- 9875
It took 25psi at 627rwhp 603rwtq to twist my axle stubs.
A NA ls1 will not do anything to the z31 rear end and stuff. -
