R30a Short Shifter Install
kaurSenior Member- 310
So that would be Nismo shifters 32839-RN595 and 34110-RN595?Originally posted by NissanEgg View PostTrying to fit a 71C shifter into 30A transmission will cause this problem everytime.
If I am not mistaken the proper shifter to use for the Z31 30A is the C's or Nismo shifter for a R32 GTS-4 with RB25 or GT-R. The R32 with 30A has the same sloping shifter plate and shifter.
http://www.nismo.co.jp/products/cata....html#page=153
The second one looks nice, but it's quite expensive, like $300-400. -
Shimming the cheap ebay shifter by 1mm worked for me. But i've only put like a mile on the car since it was installed.
I made one or two for 300zxturboftw. Haven't heard any feedback as to whether they're working for him or not.
bonfire79Senior Member- 223
its a bit shorter, not by a whole lot. and somewhat stiffer to shift for some reason, not as smooth as the stock, but it feels fine for me. you can definitely feel the throw. its worth doing i think, especially for the price of 25 bucks on ebay.Originally posted by z31_boy View Post
How was the throws and shifter feel after the install?
Bon
i thought the 240sx came with the same transmission as the z31. how different is the 30A? just wondering.Originally posted by NissanEgg View PostTrying to fit a 71C shifter into 30A transmission will cause this problem everytime.
If I am not mistaken the proper shifter to use for the Z31 30A is the C's or Nismo shifter for a R32 GTS-4 with RB25 or GT-R. The R32 with 30A has the same sloping shifter plate and shifter. -
Some Z31s had the same 71C as in 240SXs, some had the 30A that was later also used in other Nissans.
http://datsun1200.com/modules/mediawiki/?title=FS5R30A -
Sorry for late response. Z_karma was a hero and sent me some shims that worked perfectly. I still have to adjust the bolts slightly and threadlock them, but the car is driveable (sometimes notchy from 4 to 5 - as said need to adjust it). I love the short shifter compared to the stock throw, which in my opinion is way too long. Less time focusing on shifting as the throws are short and tight.Usual Z31 suspect: Garage Queen (aka broken)
FYI - don't use the crappy bushing that comes with the shifter. Spend the extra $10 and buy a new nissan one. To get it on set the bushing on something softer than concrete (wood, plastic, etc) then align the shifter pivot in there and hit it down with a rubber mallet. Should pop right on with one good tap. If you are really strapped for cash use the one on the stock shifter, but I like the ability to switch back to the stock shifter if I ever need to.Usual Z31 suspect: Garage Queen (aka broken)
