Jatco 3N71B/4N71B (automatic trans) buildup information
 Bernardd Bernardd
 CrazySenior Member CrazySenior Member- 619
 What did the manualized Keas valve body cost. Modding the separator plate looks like a lot of work and would be a lot easier just getting one from Keas.Bernardd wrote: You'll have to compare a stock seperator plate on the left in the first pic to the keas plate on the right. And yes you just can unplug the line or leave it it but it won't do anything. Neither will the kickdown solenoid.Black 1986 300zx Turbo coupe (Chuki)
 http://z31performance.com/showthread…9;s-1986-300zx
 Bernardd Bernardd
 This looks like a good shop http://www.gzm.com.au/transmissions.htmBlack 1986 300zx Turbo coupe (Chuki)
 Bernardd Bernardd
 Here is the email i recieved:
 Hi Jason Prices Below
 Stage 3 shift kit valve body only $220.00 c/o
 Full manuel valve body $462.00c/o
 Bilit Servos must be fitted with full manuel valve bodies for shift quality
 Billet servo $110.00 Each 2 are needed Regards Goran GZM
 What does c/o mean??Black 1986 300zx Turbo coupe (Chuki)
 Bernardd Bernardd
 I'm just getting ideas together for my 240sx build. What i have so far is a rust free clean 240sx with no motor a vg30, a turbo jatco 4n71b trans, and a Holset HX35. At a estimated 2500 lb race weight i may have some wheel spin issues so i was thinking about using a manual valve body to prevent wheelspin up shift problems.Bernardd wrote: Change over? Maybe he wants your valve body to modify? Or a core back? How much power are you planning on making? I found that the shift mods worked well upto 450whp. The only reason I wanted the full manual was because I needed a quicker 2-3 shift. To make it faster the throttle and govenor circuits had to be eliminated and it shifts instantly when asked to.Black 1986 300zx Turbo coupe (Chuki)
 Bernardd Bernardd
 3rd PartyJunior Member 3rd PartyJunior Member- 20
 i guess too i was kind of curious about the torque converter, 'cause it seems like you guys have the valve bodies figured out but what are you guys doing with the stock torque converter??
 Bernardd Bernardd
 maverickxeoSenior Member maverickxeoSenior Member- 650
 Stupid question:
 Can these mods (or rather, the valve body mod) be done with the tranny still connected and everything or does it HAVE to come off the engine/body? If I gave this information to a mechanic (a good one) would he be able to build it like that?
 Bernardd Bernardd
