Manual transmission weights?
blueridgespeedMember- 38
I've searched but can't find any info on the weights of the three z31 5-speeds. If anyone has weights for the FS5R90a FS5R30a and FSW71c, I'd greatly appreciate it.
EDIT. TRANSMISSION WEIGHTS ARE AS FOLLOWS:
84-89NA Manual FSW71c is 106lbs (Thanks 85NA2T)
84-86T Manual FS5R90a (T5) is 104lbs (Thanks matico40)
87-89T Manual FS5R30a is 119lbs (Thanks 1sickz)Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
spy a VG30et.. a VG30ET 510?
Tube frame "done".
12/10: Interior sheetmetal, firewall done. Fuel + brake plumbing "done". Pulled it all out again to finish the "chassis". Briefly, it drove, then back to the shop.
1/11: rotisserie built: car BELLY UP
Will now attempt an aero underbody - best keep it simple!! I have no windtunnel -
matico40Senior Member- 839
104 lbs on a T-5 without any fluid, "polished" clean (so no extra weight from all the dirt), and the bellhousing included. -
OK, so Matico has stepped up with one of the weights. Gotta love reliable information like that (I'm willing to bet that 104 lbs, clean is an accurate weight, since you didn't just say "105 lbs"!) Thank you Matico.Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
Tube frame "done".
Guest
i've carried the 90a and the 71c within 5 minutes of each other i'd say the 71c is a few pounds heavier. maybe 4-6lbs more. -
Couple days and I can weigh a 71c.
cool, I'm particularly curious about the 71c.TearingRaven wrote: Couple days and I can weigh a 71c.
https://fund-solvaren.com.Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
Tube frame "done".
85NA2TSenior Member- 1111
71c is at 106 or so."If your car cant do a burnout from a 60mph rolling start, then your engine needs more work."
Shooting for 500whp
yeah. I have the picture somewhere…digital scale too :-)blueridgespeed wrote: OK, so Matico has stepped up with one of the weights. Gotta love reliable information like that (I'm willing to bet that 104 lbs, clean is an accurate weight, since you didn't just say "105 lbs"!) Thank you Matico. -
Thank you, guys!
Matico's got a t-5 weight of 104 lbs,
Tearingraven's got a 71c weight of 106 lbs.Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
Tube frame "done".
FlawleZSenior Member- 1971
[quote]matico40 wrote:The 30A is ~150 lbs. I should have mine off entirely with a couple weeks. If it hasn't been confirmed I'll weigh mine then.Originally posted by blueridgespeedOK, so Matico has stepped up with one of the weights. Gotta love reliable information like that (I'm willing to bet that 104 lbs, clean is an accurate weight, since you didn't just say "105 lbs"!) Thank you Matico.
yeah. I have the picture somewhere…digital scale too :-)545 RWHP & 540 RWTQOriginally posted by Andrew84zx
bronzemfpSenior Member- 412
I just picked up a 30A trans. I'll weigh it when I get home tonight. She's a big gurl, hope she doesn't break the scale.
cool- the 30a was the last one we were waiting on weights of. I'm curious to see how the "big gurl" does on the scaleStarted with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
Tube frame "done".
1SickZSenior Member- 634
Lou88NA2TSenior Member- 504
the 30A should weigh more than 118 lbs. I have one in my garage and i would say it's close to 140-150 lbs.Originally posted by michaelpWhen are you coming back to the good coast? -
I edited the first post so it's in there. We still need a confirmed weight on the 30a manual and the auto transmission.
I would guess the 30A is about 120-130lbs, based on bench-pressing it into and out of place numerous times… But I'd like to hear what the scale comes up with.
