Looking for a clutch
SteveZSenior Member- 535
mylittlezMember- 78
I just installed a DXD (southbend) clutch from http://www.z31parts.com/drivetrain.html i got the TZ and the aluminum flywheel, wonderful smooth engagement that you can feel. have a few more perker-uppers ready to install then it should feel like a million bucks. keep in mind at this point i'm an almost totally stock n/a. 86 z31 n/a: 11lb flywheel, Southbend TZ clutch, all new clutch parts (master cylinder, slave, and the 280z hose installed) electric fans from a 89 maxima butchered to fit and on toggle switch (almost never turn them on takes extented 20+ min. at idle during summer before temp starts rising), I've got poly spring seats and engine mounts but they aren't on the car yet..... Let the shopping continue. -
You're wasting your time keeping your car NA. I had the same shit except the clutch and flywheel, along /w advanced ign timing, a 2.5" exhaust (no cat), and an intake…it was still slow as hell. Faster than stock, but still slow as hell.mylittlez wrote: I just installed a DXD (southbend) clutch from http://www.z31parts.com/drivetrain.html i got the TZ and the aluminum flywheel, wonderful smooth engagement that you can feel. have a few more perker-uppers ready to install then it should feel like a million bucks. keep in mind at this point i'm an almost totally stock n/a. 86 z31 n/a: 11lb flywheel, Southbend TZ clutch, all new clutch parts (master cylinder, slave, and the 280z hose installed) electric fans from a 89 maxima butchered to fit and on toggle switch (almost never turn them on takes extented 20+ min. at idle during summer before temp starts rising), I've got poly spring seats and engine mounts but they aren't on the car yet..... Let the shopping continue.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
mylittlezMember- 78
why thank you so much for your opinion that i don't care about.....now moving on without being off subject next please -
85NA2TSenior Member- 1111
:fouet"If your car cant do a burnout from a 60mph rolling start, then your engine needs more work."
Shooting for 500whp
