So i found an SS Z31… question
  • andrewhuffman
    andrewhuffman
    Member
    • 80
    My question, with the half shafts plug and play with my z32 diff i want to install?
    I have the z32 shafts and was going to attempt to modify them.
    It's in the junk yard in almost perfect condition.
    Its got 111K on the odometer.
    I debating on pulling stuff to sell , any one need anything special?
    Currently has twin piston calipers, diff, shafts, 5spd trans, complete clean motor, T-tops
    I took the rearo seats. :nanan?re
    BTW, the car was hit pretty hard in the front. The chassis is no good. The bad is that the junkyard is the most expensive one near me, i Hate it!
  • adamvann3
    adamvann3
    • 4160
    Front hubs and tension rods if they are good.
    Where are you loacated?
    86na - BlueZ
    85t - Mr Tickles
  • 88sinZ
    88sinZ
    • 2019
    adamvann3 wrote: Front hubs and tension rods if they are good.
    Jacksonville, FL? sorry no JY grab ass for you :lol:
    https://www.300zxclub.com/member.php?u=69391
  • adamvann3
    adamvann3
    • 4160
    huh?
    86na - BlueZ
    85t - Mr Tickles
  • andrewhuffman
    andrewhuffman
    Member
    • 80
    #5
    Yes, that is my profile, and i am in Jacksonville. i saw the drivers lower control arm had been cut, and i dont know if the passenger side has damage. the rim was still on. The whole strut assembly on the drivers side ws pulled to access the wastegate.
    So do the half shafts fit right in?
  • Durkin
    Durkin
    • 513
    #6
    as far as I know, the z32 half shafts will not fit the shiro VLSD (if i'm incorrect Please correct me). otherwise that'd be sweet since there are a few wrecked z32's around here.
    if it was closer i'd snag the trans - LSD and shafts as a spare, but oh well..
    SS #341
    "This car can be vicious, but in an unusual way, like a shark in a funny hat."
    -Jeremy Clarkson
  • andrewhuffman
    andrewhuffman
    Member
    • 80
    #7
    i meant the ss shafts in the z32 diff…
  • Durkin
    Durkin
    • 513
    #8
    i knew what you meant just stating that i didn't think they were interchangable. i think the z32 rear end is wider, so the SS shafts might not be long enough…
    SS #341
    -Jeremy Clarkson
  • andrewhuffman
    andrewhuffman
    Member
    • 80
    #9
    Durkin wrote: i knew what you meant just stating that i didn't think they were interchangable. i think the z32 rear end is wider, so the SS shafts might not be long enough…
    from what i read, you have to cut the z32 shafts to fit into the z31 diff because they are too long… so would the ss shafts be the right length?
  • Durkin
    Durkin
    • 513
    #10
    not sure, now i'm confused… or, I might've been the whole time… there's a VLSD thread in the Drive train section, might be in there?
    SS #341
    -Jeremy Clarkson
