Tri-Tri hybrid axle positioning spring cut?
supertoad120Senior Member- 165
I have j30/z31 hybrid t-t axles that are going in my 87. How much of this positioning spring can I cut?1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
viewtopic.php?f=13&t=15468 -
Nnever mind. I got them to fit. I had to put the wheel side in first then bring the diff side down from above the flange at an angle. Very tight fit, I'm a little worried about them binding up when the suspension is compressed.1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
Matt89Senior Member- 2380
You should check for binding when the shafts are parrellel to the ground.Bolt on, fast, z31. You can only pick two.
Yeah I'm going to jack up on the control arm and spin the wheel. I would hate to hit a bump and blow up one of my new joints. Thanks1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
