Heater heats but the fan doesn't move
Recently my Z has been not blowing heat, but rather just heating up. So my fan has stopped working. Can't even hear any motors or anything when I turn the fan on high. Has anyone else had this problem? If so, was it the fan or the switch controlling the fan? -
Regular problem. Two of my Z's work and the other two don't. Crappy sounding fan too, I suspect the fans not the switch as the more frequent culprit.Cha iro
NewJerseyZSenior Member- 191
If it turns out to be the fan, you might try getting a replacement from OEM Surplus. (Scroll down and look under CASE) For only $50 you can get the fan, motor and case. Even if the case isn't for your model year, I believe the motor and fan can be relocated to your hardware. (Perhaps someone here might know for sure --- or maybe it matches your model year.) -
I figured out it wasn't actually the fan, but the resistor itself that's failed. Is there someplace I can find this part?
FlyingTSenior Member- 1095
Always try http://www.300zxpartsforyou.com/ and ask Steve if he has the specific part.Restore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
