Bus bar for accessory power
88sinZSenior Member- 2019
Built a mycarta bus bar with a strip of aluminum.
Curious if anyone else is running one. Install is tomorrow, curious to see or hear about others experience or opinion.
Mounted on the firewall. These will be fed by terminals on the bar.
Maxima fan. (2)
Subwoofer.
Fuel pump.
Inline fuse will be ran immediately after the terminal. -
PulseCodeSenior Member- 1522
It has to start with function… forms usually follows somewhere down the road. I presently have my PWM for the water methanol spray, temporarily mounted in the location where I think the bus should go.Everything is Meaningless. -
ShamWowSenior Member- 1905
I was thinking the same thing. Those are nice.
I still would like to see your install though, when you are ready.Everything is Meaningless. -
WarOnFleshMember- 72
Probably this:Originally posted by 88sinZSwiggity swag. Fuse and relay built in!
Got a P/N?
http://www.waytekwire.com/item/46343…RO-RELAY-RTMR/ -
dharris1Junior Member- 15
