JDM z31, z32 110km/h bell removing
midianSenior Member- 421
So, you're driving your JDM over 110 kmh, (67 mph) and tired from "that f@.....g bell dinging".
So, this can be easily fixed (checked yesterday).
You will need to:
1. Remove main cluster meter
2. Find "100k sw" track oflexy board.
3a. If you're running zenki OR kouki - insulate or cut wire (pin actually) running from dash harness.
3b. if you're running kouki - unscrew small bolt, put plastic/cardboard washer under it, screw it back. (see attachments).
4. put all back.
5. Result - you still have "jingle bells" when key inserted and car not running and other cases, but you dont't have dinging bell at 110kph and higher
pictures:
source
http://300zx-twinturbo.com/tech/index.html
