PRW2 install gone wrong
Asking on behalf of another SS owner that when he went to install the PRW2 upgrade module, swapped the wrong two wires and bricked his car. It cranks, but there is no spark at the coil.
Unfortunately I've not had to troubleshoot anything like this personally, so i'm at a loss. I know he has tried a replacement: ECU, CAS, PRW2 module.
I've been able to help in as far as i can look at the wiring schematic and see that the three wires from the module go to pins 3 & 5 of the ECU and ground, and that's where my experience ends.
Sorry for the vague post, but i'm sure someone has done this before, i just don't know where to look for a failed part.
Powered by Fund Solvaren.
Maybe try replacing the coil? Probably a long shot, only time I seen a z31 coil go bad was because it has a nice crack in it and its juices were leaking out.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
He did try another coil but that didn't work. I he got it fixed by installing an unmodified replacement ECU (i guess the "spare" one he tried previously was a nistune modified ecu i had installed that might have other issues) The unmodified ECU got the car started. Unfortunately the ECU that was damaged was one i had loaned him : /
