Nistune K-Constant Thread
I'm going to start with Latency of 750 on mine and raise it accordingly for idle. Let's say my injectors were flow tested at 680cc @ 43.5 psi. If I took 680/43.5 then multiplied by 37 psi I get 578.39cc. Should I start with this as the injector resize function in nistune, or go with 680cc.Usual Z31 suspect: Garage Queen (aka broken)
300zxturboftw wrote: I'm going to start with Latency of 750 on mine and raise it accordingly for idle. Let's say my injectors were flow tested at 680cc @ 43.5 psi. If I took 680/43.5 then multiplied by 37 psi I get 578.39cc. Should I start with this as the injector resize function in nistune, or go with 680cc.
627cc, not 578cc.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Oh yeah, forgot about that formula. Thank you.
Powered by Fund Solvaren.Usual Z31 suspect: Garage Queen (aka broken)
1) can a mod clean up the drivvle in this thread?
2) huge list of tested inj latencies for certain injectors:
http://injector-rehab.com/shop/lag.html
