fuel injector upgrade
LanceSenior Member- 249
inside the 'top hat' on the stock fuel setup; http://www.redz31.com/images/fuel/injectors3.jpg
it seems as though I still have some fuel hose inside it, preventing it from coming off. What should I do?Lance 'never-ending 88na2t project' Landry
that trash. yeah. fire perhaps?Lance 'never-ending 88na2t project' Landry
matthunter1448Senior Member- 184
i just did mine i used my knife and cut all the way down then took some pliers and pulled the hose off then the metal ring came out -
craZedSenior Member- 530
not a bad idea. I ended up using mapp gas to burn up the last bit of hose. It was easy with pliers from there.craZed wrote: Dikes.Lance 'never-ending 88na2t project' Landry
84z31Senior Member- 967
it seems like there should be some sort of tool so you can get the intectors off the hoses. are they press fit. -
OR-ZmanSenior Member- 811
^Yep. But always get them in pairs. One alone can be a bad thing. :wink:Just stand back and throw money.
Performance costs money.
