fuel injector
  • fuel injector
    is it possible to mix types of fuel injectors? obviously they are the same flow rate but i mean peak and hold vs saturated? it should work as long as the voltage to the injector is correct? right? thanks matt
    At a guess, I wouldn't think so but don't hold me to it as I'm no expert on the subject. Would have thought you would have to put in 6 identical in brand etc injector.
      I really would not.
      Try not to be a Yahoo
        no.
        injectors should flow the same and spray the same.
        other wise you will have lean conditions in one cylinder and rich in others. which could cause your motor to blow up.
        the sierra club is gay!!!
          Even doing something like running 5 high impedance injectors and one low impedance injector (with a resistor) is not that good an idea.
