Detonation sensor
DaftZXMember
- 61
Detonation sensor
I have an 86 na that I swapped a 86 Turbo motor into I wasn't able to get the computer controller under the driver seat. Does anyone know where I can get one? Or if there's any way to make it work without it? -
CarelessSenior Member
- 13279
It's not under the driver seat. That's the crusty old stereo amplifier. The ECU is in the passenger side kick-panel. -
DaftZXMember
- 61
The stereo amp is under the passenger seat the service manual says the detonation sensor computer is under the driver seat… -
shromySenior Member
- 2189
No it doesnt, it is and always has been built into the ecu.Hmmm, Whats next?
84ZXT -
BLOZ UPSenior Member
- 2971
The detention sensor is in the driver's seat, yes.BLOZ UP.com
DaftZXMember
- 61
BLOZ UP wrote: The detention sensor is in the driver's seat, yes. -
michaelpSenior Member
- 9384
[quote]DaftZX wrote:Originally posted by BLOZ UPThe detention sensor is in the driver's seat, yes.
Ummm the detonation sensor is on the motor… what I'm saying is the service manual says there is a computer that controls ignition timing retardation under the driver seat.
Theft Deterrent != Timing Retard.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
DaftZXMember
- 61
Hmmmm it doesn't say that? My bad… I even highlighted it for you now if anyone has some other smartass comment I would be glad to help but if anyone does have info on this control unit it would be much appreciated -
shromySenior Member
- 2189
You need a new service manual, that is not the correct one. The 300zx has 1 sensor, no way it can detect it in each cylinder. As I already told you the detonation board is built into the ecu, this is only for the turbo model car as well. So to restate what I said, the NISSAN FSM does not locate it there, it is and always has been located in the ENGINE CONTROL UNIT. So you can believe my "smart ass comment" or, you can keep looking for a unit that is non existent.
Download one of these http://xenonz31.com/reference.html, so you dont have to ask stupid questions and be proved wrong again.Hmmm, Whats next?
84ZXT -
- 9384
michaelp wrote:
Something controlling retardation is on the drivers seat.......- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
DeleriousZSenior Member
- 6874
lmao dude you are getting trolled so hard.
the detonation sensor they're talking about is the one sitting in the seat driving the car. ie you.
there is one det sensor on the passenger side near the engine mounting bracket, it doesn't really do anything though.
1990 jetta vr6'd -
- 13279
-Strike-Senior Member
- 1968
DaftZXMember
- 61
Careless wrote: I will vouch that it's very frustrating to remove a seat with a motor that is stuck. But your "Manual" is a piece of shit and is leading you in the wrong direction to begin with. -
- 2971
AND A WARM WELCOME TO Z31P!BLOZ UP.com
