ECU identification
raddyMember
- 49
ECU identification
Hi
Can you help me identify this 300zx z31 ECU:
label contains:
A18-688 M50
there is also big 48 on label
and also separate 7514
also, I want to remove resistors in ECU according to this guide for upgrading to Z32 AFM
http://www.redz31.com/pages/fuel/afmcrap.html
but inside of ECU looks slightly different compared to picture, I cant find R201.....There are two parallel resistors, which looks like these for remove, but no R201 around.
Will I still need to remove resistors for Z32 AFM upgrade?
Thank you for your help
I need to know if will be -
bemisSenior Member
- 696
According to the number, you have a 86 - early87 ECCS. Although these types are programmable, they are nothing like the late87 - 89 models that most people use to modify. In order to make these types programmable, you have to do a couple hardware changes and move around jumpers. I'm not 100% on the details.1984 300ZXT
1986 300ZX 2x2 NA2T
2000 Porsche Boxster
2007 Toyota Yaris -
raddyMember
- 49
Thanks for reply.
According to this link
http://www.tdiclub.nl/topic.asp?TOPIC_I … um_Title=+
M50 ECU is from japan lambda Z31.
similar this one:
http://secretauto.free.fr/page/EPROM/puce_nissan.htm
so it should be z31 turbo lambda ECU.
But what is most important for me is If I have to remove any resistors (if yes, which) to make Z32 AFM work with this ECU… -
bemisSenior Member
- 696
Well, the fact is, no one has seriously used anything other than a 88 - 89 ECCS as a programmable Z31 unit. So, there isn't any technical data on the older models. I do know that the resistors that you have mentioned are in every Z31 ECCS. They are apart of an OpAmp circuit that brings the Z31 AFM signal into a range that the A/D convertor can read. If you trace the AFM signal through the PC board to an OpAmp, then those resistors used by the OpAmp can be removed, thus creating the same effect as in the 88 -89 units. Finding which resistors to remove from the OpAmp circuitry can be done through a trial/error operation or by looking up the datasheet of the OpAmp and determining which resistors perform the differential effect for the OpAmp.1984 300ZXT
1986 300ZX 2x2 NA2T
2007 Toyota Yaris -
raddyMember
- 49
Hi
Im back after some time, while my mate finish assembling his Z31. We have forst serious problem now. Engine can be started, but can rev only to about 2500rpm, then is there some kind of limiter. It is same with disconnected Z32 AFM. Also, engine die with closed throttle.
Now I can see 2 possible problems:
1, Z32 AFM itself is broken
2, ECU is in safe mode becouse of AFM problems
Regarding to previous post in this topic, I didnt remove resistors in ECU after Z32AFM installing, as I cannot find these resistors in my european ECU version. Can be this source of problem, even with disconnected AFM?
Thank you -
NaatgatMember
- 45
Thank you
