Upper intake manifold bolts- Removal
'84z31Member- 42
What tool do I use? Obviously an allen-wrench doesn't offer enough leverage or torque do budge these screws. Just a dumb and simple question but would appreciate an answer. -
TrbulntSenior Member- 347
You need a allen set for a 3/8 or 1/2 inch drive socket.
http://www.sears.com/search=allen%20…20socket%20set -
You should be careful with these, try using standard "break" procedures, like soak in penetrant, lightly heat and cool with torch and cold spray, wiggle with the wrench…
They are easy to strip, you don't want to apply a ton of torque on them -
AND FOR GLOBS SAKE..ahem
Make sure the 6mm hex head driver socket (not a cheap ass ball end from a loose kit) is seating to the bottom of the screw head.
Debris can get in there so it doesn't seat properly which makes it easier to strip out when you're gently givin' it the onions.
reddzxSenior Citizen- 6440
I have used an Allen wrench with the long plug socket from the tool kit as an extension bar after soaking the bolts in PB Blaster. I did this a couple times until I bought a good hex socket
1991 Hard-body 2WD
DeleriousZSenior Member- 6874
If you're ever in a pickle, you can slide a 6mm wrench onto a 6mm allen key for added torque.
1990 jetta vr6'd -
You guys have stripped these things? what the heck are you torquing them to lolUsual Z31 suspect: Garage Queen (aka broken)
Some of the bolts on jy cars that haven't been removed since the factory are pretty damn hard to get off there.300zxturboftw;343439 wrote: You guys have stripped these things? what the heck are you torquing them to lol
1990 jetta vr6'd -
this.i r teh noobz;343441 wrote: Tap the socket with a small hammer to make sure the bit seats all the way. -
I just stuck one of these on my small impact and zapped them right out.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
I suppose. That's why you use the socket pictured above and hit it with a hammer to break apart rust. Tap of the trigger on an impact gun then use a hand tool to remove. Wah' laDeleriousZ;343443 wrote: Some of the bolts on jy cars that haven't been removed since the factory are pretty damn hard to get off there.Usual Z31 suspect: Garage Queen (aka broken)
An impact gun is great if you have a pneumatic one with a compressor or an electric one. Often times, we have neither at the junk yard.
1991 Hard-body 2WD
For sure. I've got a cordless one that just destroys shit and has great battery life. Been a life saver at the jy a few times already.reddzx;343505 wrote: An impact gun is great if you have a pneumatic one with a compressor or an electric one. Often times, we have neither at the junk yard.
1990 jetta vr6'd -
I always take both my big and small electric impact with me to the yard.reddzx;343505 wrote: An impact gun is great if you have a pneumatic one with a compressor or an electric one. Often times, we have neither at the junk yard.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build
