Ideal Ignition timing , for a Nistuned GT35 1bar boost on a 7.8 to 1 bottom end
jamesSenior Member- 978
Hi Guys
I need some inspiration before tackling the ignition timing maps in nistune on my now GT35 VG30ET, i have run up to 19 psi successfully on 20deg base timing, and un modified stock timing map, no signs of det. always used highest grade fuel avalible to me.
However, in the lower revs it feels a bit sluggish, the physically bigger turbo is a bit slower responding than the old T3 so my thoughts were to do some road testing carefully adding in a little bit of timing in the lower revs until i reach something like 5psi of boost. Then do the rest of the timing on the dyno.
( dyno tuning time in New Zealand is pretty expensive. usually a tune on something boring like a wrx runs like $1200 )
I am running good fuel, inter cooled and and fuel AFR's are nice and safe but not mega rich.
0-5 psi is in the 13's , 5-10psi in the 12's and 12 - 15+ psi into the low 11's to about 5k
and from 5k to the 6.5k it dips into the high 10's just as the redline is reached.
Please post a description and a pic of your timing map. Not many guys tune VG's here in New Zealand so i want to get an idea of where they like timing before making any adjustments.85 Turbo Slick Top
From the tuners I spoke to, it behaves very similar to the rb30et… so any tuner familiar with that should have no trouble -
300zxtravisMember- 98
no real responses ehh? I am also looking for some timing map ideas as well.. Though compared to my maps and reading you are running a bit excessive on the retard side. I have always been advised to try not to go under 13 as it starts to cost you power/efficiency. you can run a full 20-25 deg fo quite a ways up rwithout retarding so dramatically with good fuel. DO you have a WIDEBAND O2? The way we have tuned on the street is set our max boost say 15psi and drive the car around doing some runs watching the 02 meter then kept adding fuel to it until it was nearly pig rich around the 12.7ish then go back and add ignition timing "advance" until either det occurs or the meter reads at desired AFR.
IF i recall correctly the vg30 doesn't reach Peak pressure until right at 14-15degrees after TDC due to combustion chamber design and modern fuel changes. Thats why we can advance the timing out so far on the N/A engines. High octane fuel would extend that out a tad more.
It is safe to say you can easily add ~4 degrees in the lower ranges and 2 on the top. I always run pretty advanced up to 5psi to spool up quicker then retard. as my map sensor I can adjust every PSI of boost to a set timing. But I strongly suggest getting a wideband pouring fuel down its throat and adding timing. this keeps it to adjusting 1 variable at a time. I dont have picture of my maps sorry. and I am resinstalling my stand alone in a new car so it will be a week or 2 as i need monies. -
slammedfcSenior Member- 288
What the guy above me and ge said. L28 engines are similar as well. Best thing you can do is build yourself a det can. Old school copper tube style or electronic. Choice is yours. When you hear light knock, back off timing a degree or 2 and leave it alone if the afr is where it needs to be. That's the rule of thumb i've always been taught. Everyone's map is gonna be different.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
L engines have horrible combustion chambers and non-crossflow design. You can run a crap more timing and compression on RB30E(T) and VG3xE(T) heads without issues than you can with Ls.slammedfc;346678 wrote: What the guy above me and ge said. L28 engines are similar as well. Best thing you can do is build yourself a det can. Old school copper tube style or electronic. Choice is yours. When you hear light knock, back off timing a degree or 2 and leave it alone if the afr is where it needs to be. That's the rule of thumb i've always been taught. Everyone's map is gonna be different.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Yep Tech Edge Wideband, and usb consult Nistuned.300zxtravis;346650 wrote:
It is safe to say you can easily add ~4 degrees in the lower ranges and 2 on the top. I always run pretty advanced up to 5psi to spool up quicker then retard. as my map sensor I can adjust every PSI of boost to a set timing. But I strongly suggest getting a wideband pouring fuel down its throat and adding timing. this keeps it to adjusting 1 variable at a time. I dont have picture of my maps sorry. and I am reinstalling my stand alone in a new car so it will be a week or 2 as i need monies.
Interesting, I was under the impression in the 10 AFR's was pig rich and that around 11.5's were ideal for around full boost pressure. It sounds like the fueling side of it is safe enough to leave alone for the minute, and to start adding some timing up to around 5psi of boost.
With the GT35 it always made the boost pressure nice and early but it felt lazy until about 10psi. In general terms above 4000rpm always felt really strong. So I'm not familiar with these old school det cans.
Since I posted this i have pulled the car down for tube manifolds and a 600x300 inter cooler with associated piping. I am hoping that with more timing and less back pressure i can really make some power.
Cheers, James85 Turbo Slick Top
Most power will be had at high 12's as they precede the boost ramp with extra fuel then… the only reason to touch 11's is for extra chamber cooling, useful if you haven't got your timing right or your intercooler isn't as effective as it needs to be -
Listen to G-E. He's right on the money.
As far as det cans go, electronic will give you an unmistakable sound once you start knocking.
Electronic (diy modified mechanic's stethoscope)
http://www.youtube.com/watch?v=t4mZ2FMLC4A[/video]]
What it sounds like
http://www.youtube.com/watch?v=GGJZ6kKzLus[/video]]
The copper style sounds like bb's bouncing around inside the tube. Just keep advancing to where you are BARELY hearing knock then go 1-2* under the knock limit. Add fuel if you need it. Timing will change afr. Still fairly new to tuning these motors but the basics apply to all engines....unless you're rotary. Any knock is bad. In boost that spells end game more often than not. I run a very paranoid 15* base timing on my 10:1 vg30et. Max advance at low boost at 6800rpm is something like 25-26*. Lol.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
FlawleZSenior Member- 1971
I would NOT tune a turbo car for AFRs in the mid 12s at peak boost prrssure. That will be a recipe for disaster I can assure it.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
you should be in the 11.5-11.0 range in boost wot. Part throttle, 12's are acceptable.
we should have a stickied map sharing thread with rules/guidelines posted.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
I agree with what they say, sounds like your on the right track. I said 12.7 though i may have ment 11.7, it has been 5-6 years since i last tuned an engine. but i remember something about 12.7 pretty vividly, maybe i was having DET at 12.7 been a while. either way you can add some timing just keep watching your afr, it likely feels sluggish because of the amount of retard. you are better off advancing your timing and adding more fuel then retarding your timing, to an extent of course its give and take.
