Injectors maxed out?
 onefast87Senior Member onefast87Senior Member- 696
 Injectors maxed out?Im running 500cc injectors with a walbro 255, stock fuel pressure, with a hy35 and the injectors seem to max out at 17-18 psi.MS2 is the ecu.
 I could run 11 psi on the stock injectors before the duty cycle went over 90%.
 Does this seem right?
 I was hoping to max out my map sensor at 21 psi before the injectors quit.http://www.youtube.com/user/onefast87
 Kimbro SliceSenior Member Kimbro SliceSenior Member- 1561
 Do you have a fuel pressure gauge on the rail? Usually aftermarket fuel pumps bump up the pressure in the rail, even if you're running larger injectors. Not that the fuel pressure could max the injectors that hard or anything, but just a thought.
 2001 Mazda Miata LS
 also a 1989 Nissan 240SX
 50th AE Build Thread SOLD 2015
 FlawleZSenior Member FlawleZSenior Member- 1971
 Just shooting in the dark without knowing fuel pressure.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
 Last time i tested it had good fuel pressure.
 I was thinking about installing my aeromotive fpr this weekend!http://www.youtube.com/user/onefast87
 Chrisw_2003Senior Member Chrisw_2003Senior Member- 2503
