Fuel Injector O-rings
Do you need special o-rings for E85? Where can I find some ethanol grade 11mm's for rx7 injectors?Usual Z31 suspect: Garage Queen (aka broken)
FlawleZSenior Member- 1971
I'm running standard rings. I don't believe its neessary to run anything any different as all the modern hoses and rings are made to withstand ethanol content in gasoline since the 80's.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
