It's Alive. Not tuned but the SDS is running.
300zxtravisMember- 98
Just thought some people would like to see some early stages of the SDS install. Caught heck getting it going because of dumb stuff like fuel pump cutting out, MSD box going retarded. The engine is Idling pretty good at ~850Rpm The ignition timing is pretty much at zero the light is triggering on my TDC mark. I haven't Set up anything at all in the values. I caught hell getting it going because i was using my old load out. well, that was 550cc injectors 2 bar map, and other stuff. changing everything to run stock injectors was getting tiresome so i Dumped EVERYTHING and have a full zero flat line map, fuel only to 1200 rpm. have values for 3 bar map entered, waiting on my potentiometer to do load scales, nitrous and launch control circuits. you can get a basic idea of some of the values as i scroll through the tuner.
http://www.youtube.com/watch?v=xH7Z5fY3vPQ[/video]]
