quick ecu question
 zlover23Senior Member zlover23Senior Member- 291
 quick ecu questionQuick question, will an 87t ecu work in my 86t car? I've read that both are for titania o2 sensors and low impedance injectors, so it should work fine right? I can find 87t ecus but not any 86t's.
 '86 NA2T: Cone filter, 3 in. turbo back, poly engine mounts, stock t3, tokico 5-ways, rattle canned engine bay, etc etc
 "As I lay rubber down the street, I pray for traction I may keep, and if I do begin to slide, please dear God protect my ride! - Amen!!!!"
 Yes, it should work. I've seen people mentioning using 87T ECUs on their 84T and 85T cars. http://www.redz31.net/pages/fuel.htmlPrius… because Pretentious wouldn't fit across the back of the car…
 My 1986 Turbo Build
