Radium FSTR returnless swirl tank on RB opinions?
http://www.radiumauto.com/FST-R-Fuel…-FPR-P348.aspx
Scenario: my racecar has no battery tray, so that's the perfect spot, rb intake is on that side, no danger with heat, as are the fuel lines to the gas tank…
My thought centers around using a standard aftermarket rb25 topfeed fuel rail (not like raw brokerage's rail with a port for return in the middle), and have the two ends routed back to a Y-block with a fuel pressure gauge into the swirl tank
Discuss?
Although a very cool idea, seems a little overkill. Raw brokerage fuel rail is based on the greedy. I would stick to a standard aftermarket fuel pump and reg an lines etc. Spend the time on a fuel cell.. Maybe more worth your while in the end.87T, My build thread http://z31performance.com/forum/z31-…lee-s-87t-rb26
