stock z31 tables
kairamielJunior Member- 8
stock z31 tables
Will somebody post a screenshot of the fuel and ignition tables from the stock z31 ecus? I am tuning my engine from scratch with a haltech sprint 500 and would like to have stock tables, preferrably na and turbo to reference from. Fuel and ignition please! Thanks, if possible!1987 rx 7 with vg30e swap -
slammedfcSenior Member- 288
If you get a pm or an email consider yourself lucky. I've been tuning my stand alone from scratch. Props to you for putting a vg into an fc. Most people do not want to post maps because they dont want to be held responsible for user error, acts of god, etc.... maps from a stock na and both variants of turbo block compression would have helped me out with months of hard work out on the street meticulously tuning my car. It's a pain in the ass doing it that way… I'm still very apprehensive to share my maps with anyone. It's not about the money, it's about keepign people safe and i swear if i had those maps i'd open source the hell out of them to do just that.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
I was hoping it wouldnt be a big deal. I see people posting stock nistune bins all around, but i cant actually see the tables. Can i download nistune and open up the tables to view them on my own? Or does nistune only work if you have a nissan ecu plugged into it. I know the load scales are different, but im confident i will be able to get a start from there. Fuel tables are simpler because you have 02 feedback and an engine can operate under a fairly wide afr range. My most difficult area is ignition timing maps, Creating one from scratch with absolutely no references. Maybe someone can throw me a tip or two on ignition timing theory?1987 rx 7 with vg30e swap -
Rustspecs13Senior Member- 283
You should be able to download nistune and use it as a trial and view anything you want that way.
If guys can't find I can screen shot my laptop later tonight.
~Alexsplatter fake blood on fubar'd quarter and roll out.
pedestrians=mobile clipping points -Benedict on PurePontiackid's 280zx -
Apparently we need a timing map sharing thread. At least if someone has a timing map they can just start pig rich then start tuning from there. I can't see that going over well though....vg30'd s13 in progress. Shocks. Pegs. Lucky. -
SilliJunior Member- 15
VG30ET eurospec
For your eyes only
… seems that forum is chewing out the picture..
vg30etstock.jpg -
Just curious. What's the left to right top row values scaled from? Can't be kpa or psi.....vg30'd s13 in progress. Shocks. Pegs. Lucky. -
