Adding NOS to a 87 N/A
 mprice7725Junior Member mprice7725Junior Member- 26
 Adding NOS to a 87 N/ADoes anyone have any experience adding a NOS kit to a N/A? If so wet or dry? NOS kit manufacturer?
 shromySenior Member shromySenior Member- 2189
 wet is always better. any reputable brand is fine. i prefer NOS brandHmmm, Whats next?
 84ZXT
 TrbulntSenior Member TrbulntSenior Member- 347
 How big of a shot you looking to run. I would start with a 50 dry shot before the maf and verify with a quality wideband your a/f ratios. Just verify your ignition is in 100% working condition and your timing is set correctly. I would also look into running a step colder spark plug to be safe. In reality you'd be better off going with an NA2T setup.
 Ski300zxSenior Member Ski300zxSenior Member- 454
 I have been running a 90 shot for the past few years on my NA2T and it works great. pull 4 degrees of timing (general rule is 2 degrees for every 50hp of shot). I have the bottle in my spare tire well, ran the line up to the solenoids, and i have a fogger installed a few inches before the throttle body. I am wired into the TPS for wide open signal, and i have the arming switch in the cockpit. just make sure you are over 2500 rpm when u spray. However, I have a turbo, and the hot charge air coming out of the compressor is perfect for making sure the nitrous and fuel get spread all around. Never ran N20 when I was NA, but I think a 100 shot should be fine. just make sure the fogger sprays directly into the throttle plate area and not against the wall of the charge pipe.Ride it like you stole it…
 1986 300zx NA2T - CM 3" turbo back, Pathy 3.0 Engine, Custom cold air intake, 255lph Walboro, T3 turbo, 90 shot of nitrous, 30A trans, 88t LSD, Poly everywhere, SS brakelines. 288whp 336wtq
 2001 YZF600 - Sold for Nitrous and Exhaust Upgrade…
 1993 Toyota Corolla - The invincible daily driver, off to greener pastures.
 2002 Nissan Maxima SE - New daily driver
