fuel pump assembly
Returned Z31 LoverSenior Member- 144
fuel pump assembly
- 8 feed and -6 return
I need some help with this guys. I've heard from some of my supra friends and even some z guys that I can just completely delete the stock pump and run a hose straight down in place of it with a sock filter at the bottom? Or I had originally planned to use the stock pump as a feeder pump. The stock pump wires are crap and I don't wanna deal with wires touching later and leading to something very bad. Advice?
THE ONE AND ONLY AE 2JZ Z31 IN THE WORLD -
88sinZSenior Member- 2019
yes you can run a feed line to pump out of the tank if you plan to run an inline filter before the external mount pump. Always worth running a post pump filter as well.
aeromotive makes a nice screen filter with AN fittings that could be used pre and post pump.
I'm looking to do similar to your setup PN's for the fittings and grommets plz? -
Thanks bro I just wanted to be sure cuz that setup sounds too simple to be true…once again I just completely delete the stock pump and run a line connected to the bottom of the -8 fitting? I just want to be sure…and the fittings I got on ebay I'm running an a1000 pumpOriginally posted by 88sinZ View Postyes you can run a feed line to pump out of the tank if you plan to run an inline filter before the external mount pump. Always worth running a post pump filter as well.
I'm looking to do similar to your setup PN's for the fittings and grommets plz?THE ONE AND ONLY AE 2JZ Z31 IN THE WORLD -
Ideally you want to run a sump like this http://img.photobucket.com/albums/v3…a/DSC00680.jpg to prevent air from entering the lines. You can pick up a pre-made sump that can be welded on from most performance retailers, i'd suggest Pegasus -
The sump is nice but keep in mind I might be running a 2jz but im still a cheap z31 owner lol so my budget is kinda tight and if I get make things work good and safe without paying too much I will. I just wanna get the car running then comes all the nice stuff laterOriginally posted by 88sinZ View PostIdeally you want to run a sump like this http://img.photobucket.com/albums/v3…a/DSC00680.jpg to prevent air from entering the lines. You can pick up a pre-made sump that can be welded on from most performance retailers, i'd suggest PegasusTHE ONE AND ONLY AE 2JZ Z31 IN THE WORLD -
boosted300Senior Member- 195
Completely deleted stock pump, imo it will be an impediment trying to feed another high performance pump anyway.Originally posted by Returned Z31 Lover View PostThanks bro I just wanted to be sure cuz that setup sounds too simple to be true…once again I just completely delete the stock pump and run a line connected to the bottom of the -8 fitting? I just want to be sure…and the fittings I got on ebay I'm running an a1000 pump
Bosch 044 pump in place of stock pump with a fuel sock…it has worked great for me.
