86T NA-T Nistune ~2500RPM lean spike issue
ozzyrulezSenior Member- 631
Here is a question. Does it do it only while Consult is connected or does it do it all the time? I had many many issues with Nistune, one of them being it stumbling and carrying on while Consult was connected but it ran absolutely fine disconnected. -
Axel kainModerator- 1221
all the time, and as far as I can tell it is NOT Nistune related, as it did it with my perfectly fine working nistune'd ecu from my car, I just plugged in and adjusted for the larger injectors, fired it up. it did the stupid lean spike issue as soon as I took off in first and 2nd. so pretty much all I can think to do is just start trading parts between my good running car, and this one, as well as maybe make a new simplified engine harness for posterity sake.Damn dirty angels....these cars!
sigpic -
NissanEggSenior Member- 5220
Start with CAS -> MAF -> TPS -> harness
so with that logic, I need to deal with the harness. CAS has been swapped a couple times, MAF has been changed with no avail, and TPS is working fine, even with it disconnected (non idle signal) makes no difference.Damn dirty angels....these cars!
sigpic -
Ain't no problem like a wiring problem. Good luck with that sir! -
When you say CAS, are you swapping just the CAS alone or the entire distributor?
If not the entire distributor I would try that to rule out a bad bearing in the bottom of the distributor that can allow a wobble in the shaft and screw up the CAS signal.
I'll change out the whole thing just to see then! it's been just the CAS I was replacing… thing is, it did great when we had it on the dyno first, until it burned up the fuel pump ground circuit trace in the ECU. I have since rewired the pump, and am running the other ECU.Damn dirty angels....these cars!
sigpic -
So, I have swapped distributor assemblies, with a known good running one, to no avail. Im thinking about pulling the valve covers and measuring the cam specs, and comparing to the card. they're the only other thing that have changed since the first dyno session where this issue was not present.Damn dirty angels....these cars!
sigpic
