84 Turbo 5spd ECU in 86 Turbo Auto car,
 MattC300ZTMember MattC300ZTMember- 69
 84 Turbo 5spd ECU in 86 Turbo Auto car,As the title says, my 84 parts car is turbo and 5 speed. The car I'm restoring is an 86 turbo auto, can I put the 5 speed ECU in the auto car and will it be plug and play? I'm doing a manual swap otherwise I wouldn't bother lol. They are both federal if that info is needed, I know the 88-89 have different injector programs. I just don't want to swap them and cause a major issue.-1977 280Z, 5 speed, light Blue
 -1986 300ZX, Turbo, GLL, Grey Metallic, (will be Sliver metallic), (Project)
 -1984 300ZX, Turbo, GL,(Parts Car)
 -2003 350Z, 6 speed (Dads)
 reddzxSenior Citizen reddzxSenior Citizen- 6440
 84-85 ECU has cold start issues
 1991 Hard-body 2WD
 amrebootBanned amrebootBanned- 9875
 Yes, you can.
 You can run an auto ECU in a manual car, just make sure you set the timing for the ECU being an auto.
 Also, 84t and 86t have different O2 sensors.
 http://www.redz31.net/pages/fuel.html
 I've read the tuning required to keep the auto trans ECU, I just wanted to drop in an ECU and not have to worry, the 60MM throttle body i got has a screw port for idling. So i was just going to have that there for idle. So ideally I should get an 86/87, Turbo, Federal, 5 spd ECU and that would be perfect for my car?-1977 280Z, 5 speed, light Blue
 Yes and pick the o2 sensor then wire it in if necessary to match the ecu you pick.http://z31performance.com/showthread…2-2-(-now-NA2T
 My build thread (:
 Okay, thanks guys, ill be on the look out for one of those!-1977 280Z, 5 speed, light Blue
