Fuel Filters: Z31 vs Z32
ZR_Down_UndahBanned- 76
I watched a thread develop on Facebook, and am curious as to what the forum has to say. What's the verdict on running a z32 fuel filter on our cars? I'm assuming lower MPGs is a byproduct of running a bigger filter, right? -
Yeah, I really don't see the benefit. If you're looking for more flow or something, look into some kind of aftermarket filter.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
I heard the z32 filter out flows the z31 one. It is definitely larger.... flow more? Well I didn't notice a difference.http://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (: -
Larger /= more flow. Like said, makes more sense to just do an aftermarket filter. If you're needing that much more flow, you're going to be running AN lines at that point anyway, so might as well get a filter with AN inlet and outlet.Originally posted by les_joey_paulI heard the z32 filter out flows the z31 one. It is definitely larger.... flow more? Well I didn't notice a difference.Prius… because Pretentious wouldn't fit across the back of the car…
ralph50Member- 53
ozzyrulezSenior Member- 631
I was making about 400 to the wheels and was having no issues with fuel delivery using a factory filter. -
zdriver_kadoMember- 100
I've experienced no flow difference between them with the stock fuel system. The z32 filter flow ceiling is higher. Pumps won't care but interesting to if it would reduce current draw in certain situations. -
I think a lot of people here have made 400+ on stock filter. I would suggest once you go to -6 or -8 an to upgrade to an inline filter that flows better so you don't have to worry about it going forward.Usual Z31 suspect: Garage Queen (aka broken)
GregmaticSenior Member- 2193
