Anyone on here using F.A.S.T???
ralph50Member- 53
I'm getting a really good deal on one.
I considered Nistune but my entire engine harness is falling apart and don't want to deal with 31 year old sensors. -
I wasn't aware they made anything not intended for an LSX/SBC. What product are you planning to use, exactly?Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
ozzyrulezSenior Member- 631
Wow for the price just their ECU you can get Megasquirt 3 with Megasquirt Extra with both harnesses, VG30 trigger wheel, boost control solenoid, GM CTS and GM IAT with pigtails, the knock module kit, their "MAP Daddy" 4 BAR dual MAP. Then you can use the rest of the money you save to buy LSX coil packs to do full sequential fuel and spark. -
ralph50Member- 53
Its the Felpro FAST aka FAST Classic.
I'm switching to GM sensors and a wideband O2 sensor.
I'm partial to this unit as my buddies have used it before. -
ralph50Member- 53
I'm getting it for $650Wow for the price just their ECU you can get Megasquirt 3 with Megasquirt Extra with both harnesses, VG30 trigger wheel, boost control solenoid, GM CTS and GM IAT with pigtails, the knock module kit, their "MAP Daddy" 4 BAR dual MAP. Then you can use the rest of the money you save to buy LSX coil packs to do full sequential fuel and spark. -
From the way things are going so far, it seems like you'll have to get help from your buddies then, as I don't think anyone here has used any of the FAST stuff. Definitely post a build thread or something, in case someone else decides to go that way.Prius… because Pretentious wouldn't fit across the back of the car…
turbofedzSenior Member- 289
ralph50Member- 53
Thanks for the input. It might be a while though as there are a few custom parts to build.
My buddy ran this ECU on his turbo SBC so he is familiar with the system. -
NissanEggSenior Member- 5220
Are you trying to adapt this system to a Nissan V6?
ralph50Member- 53
Yes. I'm doing away with the Nissan harness and sensors. Going with GM sensors, Mototron 60# injectors, custom manifold and BBK throttle body.Are you trying to adapt this system to a Nissan V6?
