Dropping Resistors to run 72lb injectors on my SS
hds84tMember- 45
I know 6-10 ohms are ok to use as long as they are 10W. I've read several threads to educate myself but the more I read the more I worry. Lol. I hate doing electrical stuff but it has to be done.
My question is this, I typically see people running 6.8ohm for 450cc injectors But my injectors are much larger, should I go with a lower ohm or with 10ohm resistors??
3 local shops I called today do not carry 6.8ohm but they do carry 10ohm. What do you guys think??Shiro #562
vg33et66- satan log manifold- satan racing plenum- 800cc o-ring injectors- Schneider
s2 cams- Schneider valve springs- jwt 450hp kit- stance gr+ coilovers- Starion Wheels
soon to be replaced by Epsilon Southern Ways 16x10 3piece wheels
sigpic -
88sinZSenior Member- 2019
High impedance, high flow injectors are common enough just save yourself the trouble and select the corresponding impedance.
Trust me, i just pulled the resistors and rewired the EFI harness this weekend going from low -> high impedance. -
Axel kainModerator- 1221
If you still want resistors, I can get this brand's products through my work…
http://www.nteinc.com/resistors.php?a=11Damn dirty angels....these cars!
sigpic
