ECU swap
 Eric87zxBanned Eric87zxBanned- 2
 ECU swapI have a 1987 300zx turbo with low impedance injectors. I recently got a 1988 turbo ecu with high impedance injector reading. I know you're suppose to wire in some resistors to fix the high and low problem. Other then that will I need to do any other wiring to make this ecu work?
 bonfire79Senior Member bonfire79Senior Member- 223
 might be easier to just swap out your low I injectors for some high I injectors from an 88 turbo car
 Bon
 I plan on going with a Jim wolf ecu and their injectors they recommend to use with the tune which I think are high.
 amrebootBanned amrebootBanned- 9875
